LG Rebel 4 LTE Disassembly
  1. LG Rebel 4 LTE Disassembly, Remove the Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove the Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the indent on the back left side of the phone.
    • Insert the opening tool into the indent and pry until it pops.
    • Remove the backing.
  2. LG Rebel 4 LTE Disassembly, Remove Internal Components: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove Internal Components: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove Internal Components: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to pry the battery out.
    • If installed, pop out the SD/TF card by gently pressing in and releasing the SD card. Not pictured, Located above the Sims card (See Below).
    • Use your fingers to remove the sim card.
  3. LG Rebel 4 LTE Disassembly, Remove Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove Screws: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove Screws: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the #000 Phillips screwdriver, remove all the screws (as seen in the photo).
    • There should be 12 screws in total.
    • Don't lose the screws!
  4. LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to carefully pry the cover around the charging port.
  5. LG Rebel 4 LTE Disassembly, Remove the Screen: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove the Screen: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove the Screen: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the phone (view picture) to reveal the top corner of the phone.
    • Using a opening pick, pry in between the glass screen and the framing.
  6. LG Rebel 4 LTE Disassembly, Remove the Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove the Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove the Motherboard: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry from the top and bottom of the screen with the (refer to photo) opening pick to release the tabs holding the motherboard to the phone.
    • Do not let the main camera fall out while removing the mother board.
  7. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • On the bottom right of the phone, locate a cable that holds the motherboard to the phone.
    • Disconnect the cable by gently pulling up on the component with your fingers.
    • Do not use a prying tool or screwdriver to disconnect the cable.
  8. LG Rebel 4 LTE Disassembly, Remove the Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove the Camera: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Rebel 4 LTE Disassembly, Remove the Camera: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the camera from the magnet by gently pulling up.
  9. LG Rebel 4 LTE Disassembly, Disassembly Complete: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Congratulations. You've successfully disassembled your device.
    • To reassemble the device, follow these steps in reverse order. (Begin with step 8, continuining until you end on step 1.
    • When reassembling, make sure that each component snaps tightly to the phone before moving to the next step.
JCJR
crwdns2935283:006/23/23crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 587
