LG Realm Motherboard Replacement
crwdns2869540:0crwdne2869540:0: 1,9K
8
26
92
1.883
crwdns2959984:0crwdne2959984:0: 4
crwdns2959974:04crwdne2959974:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:010crwdne2931287:0
Before continuing, make sure the device is powered down. Also make sure that the battery and back casing are removed.
    1. LG Realm Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Realm Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To remove the back, insert thumbnail into MicroUSB port, and pull up to loosen back.
      • Use nail to loosen case on all four sides. Once loose, remove back case.
    2. LG Realm Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Insert thumbnail into tab below battery.
      • Pull away from phone and remove.
    1. LG Realm Motherboard Replacement, Plastic Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Realm Motherboard Replacement, Plastic Midframe: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the back cover and battery are removed, use the Phillips #J000 screwdriver to remove all 11 screws located around the plastic midframe.
    2. LG Realm Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the plastic opening tool, carefully pry and separate the plastic midframe from the rest of the phone.
    1. LG Realm Motherboard Replacement, Rear Facing Camera: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the rear facing camera.
      • Using the plastic opening tool, pry apart the cable from where it connects to the phone.
    2. LG Realm Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After removing the ribbon cable, the camera should be easy to remove with your fingers. Remove the rear facing camera.
    1. LG Realm Motherboard Replacement, Front Facing Camera: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate the front facing camera in the top left hand corner of the motherboard. Using the plastic opening tool, separate the ribbon cable from the phone.
    2. LG Realm Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • After removing this ribbon cable, you will be able to easily remove the front facing camera with your fingers.
    1. LG Realm Motherboard Replacement, Motherboard: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Locate where the motherboard connects to the orange sisterboard. Using the plastic opening tool, disconnect the connection between the phone and the orange ribbon cable.
    2. LG Realm Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Realm Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Locate the ribbon cables in the top right corner of the motherboard. Using the plastic opening tool, remove the ribbon cables from phone.
    3. LG Realm Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the plastic opening tool, disconnect the ribbon cable that connects the antenna to the motherboard.
    4. LG Realm Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using the plastic opening tool, carefully remove the motherboard from the phone.
Ryan St Martin
crwdns2935283:003/05/16crwdne2935283:0
785 crwdns2915208:0crwdne2915208:0
Marist, Team 1-5, Laflen Spring 2016 crwdns2935289:0Marist, Team 1-5, Laflen Spring 2016crwdne2935289:0
MARS-LAFLEN-S16S1G5
crwdns2936753:030crwdne2936753:0 92
crwdns2959996:0crwdne2959996:0 1,883
