LG Power Screen Replacement
Nadia Wilson
crwdns2944107:0crwdnd2944107:0Nadia Wilsoncrwdnd2944107:0crwdnd2944107:0crwdnd2944107:03crwdnd2944107:0crwdne2944107:0
crwdns2944111:0December 18, 2021crwdne2944111:0
crwdns2931287:020crwdne2931287:0
crwdns2937803:0crwdne2937803:0
crwdns2942287:0crwdne2942287:0
This guide is made to help remove the screen from your phone if you are having problems with it or need to replace it. Be careful while removing the back plating, mid plating, and screen. If this is your first time removing a touchscreen seek the help of a professional, because you may accidentally caused the image on the screen to after you put the phone back together.
crwdns2944105:0crwdne2944105:0
  1. LG Power Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Power Screen Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
    • A metal spudger can easily damage your device. A plastic opening tool is always the only option.
  2. LG Power Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Carefully pop the back panel off and place it to the side.
  3. LG Power Screen Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the thumb tab to remove the battery.
  4. LG Power Screen Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eight 4mm screws along the side of the mid panel using the Phillips #000 screwdriver head.
  5. LG Power Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide a plastic opening tool between the mid and front panel to remove the middle panel.
    • Place the mid panel to the side.
  6. LG Power Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Power Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Detach the motherboard and touchscreen from each other by using a plastic opening tool.
    • The motherboard will then be free from the phone.
  7. LG Power Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Power Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Power Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After removing the motherboard, slide a thin plastic opening tool between the screen and the frame.
    • This step may take awhile, because of the glue keeping the frame and screen together.
    This phone is not difficult... Replacement takes 15 mins
    Timothy Fogg - crwdns2934203:0crwdne2934203:0
    I can't loosen the screws on the lg x power. Help
    Tim Buendia - crwdns2934203:0crwdne2934203:0
    how much is it cost to fix a phone screen
    David Wessel - crwdns2934203:0crwdne2934203:0
crwdns2935229:011crwdne2935229:0
Nadia Wilson
crwdns2935283:002/09/16crwdne2935283:0
889 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 4-6, Lacy Spring 2016 crwdns2935289:0USF Tampa, Team 4-6, Lacy Spring 2016crwdne2935289:0
USFT-LACY-S16S4G6
crwdns2947412:09crwdne2947412:0
do i need a replacement screen?
jj - crwdns2934203:0crwdne2934203:0
My screen is shattered otherwise the phone works fine..touch works and screen under glass is good. I want to replace the screen myself but my question is are the screen and digitizer fused (one piece) or can I just replace the glass screen? For an LG power x
Nikki - crwdns2934203:0crwdne2934203:0
Did you ever figure out if there the same or separate. I'm needing to do the same.
sarahelizabeth0526 -
Where do I buy the glass panel?
Liam McBride - crwdns2934203:0crwdne2934203:0
i got the glass screen at amazonbot most digitisers have a ribbon wire to connecttheres doesnt..not sure if its just held on with 2 face tape??
Peter Maggiop - crwdns2934203:0crwdne2934203:0
my screen wont work you cant see anything and touchscreen wont work what glue should i use
King J is a massivegamer - crwdns2934203:0crwdne2934203:0
help i cant answer calls or look at nonifications
i have clean it but is can.t work so now
Rashid king - crwdns2934203:0crwdne2934203:0
Can I use lg power screen to lg leon?
Thanks
M. Jane Alam Khan - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 26,120
