LG Optimus T Motherboard Replacement
  1. LG Optimus T Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus T Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus T Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
  2. LG Optimus T Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
  3. LG Optimus T Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a J0 screwdriver to remove the six 4.5mm screws.
  4. LG Optimus T Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus T Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic opening tool fails
    • Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
  5. LG Optimus T Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull up on connector tab
  6. LG Optimus T Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus T Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove SD card mount. Insert the plastic opening tool on the right side to pop off
  7. LG Optimus T Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus T Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove metal panel
    • There are four retaining points to insert plastic opening tool and pop off panel
  8. LG Optimus T Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
    • Remove motherboard
stacey
crwdns2935283:002/07/17crwdne2935283:0
219 crwdns2915208:0crwdne2915208:0
Ohio State, Team 1-3, Wilder Spring 2017 crwdns2935289:0Ohio State, Team 1-3, Wilder Spring 2017crwdne2935289:0
OSU-WILDER-S17S1G3
crwdns2942667:0crwdne2942667:0 440
