This guide provides instructions on how to replace your broken home key and power & volume buttons on your LG Optimus T.
Using a prying device, such as a Spudger, remove the phone's back cover. At the top of the phone, there's an indentation to put the Spudger into to pop the case off.
Remove the battery. There's an indentation to the left of the camera lens to pull up on the battery with your finger.
Use a J0 screwdriver to remove the six 4.5 mm screws.
Remove interior case. Insert the spudger into the indentations at the top or bottom of the phone to pry off the interior case.
Remove power button found on top of the phone.
Remove the volume button found on the side of the phone.
Remove SD card mount. Insert a plastic opening tool on the right side to pop off.
There are 4 retaining points to insert a plastic opening tool into and pop off panel.
Remove 2 black J0 Phillip's head 1.8 mm screws from charging port.
Remove motherboard.
