LG Optimus G Pro Battery Replacement
  1. LG Optimus G Pro Battery Replacement, Remove Back Cover.: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Battery Replacement, Remove the Battery.: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
crwdns2935229:010crwdne2935229:0
Wesley Pate
crwdns2935283:009/25/14crwdne2935283:0
1.641 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 15-5, Remmell Fall 2014 crwdns2935289:0USF Tampa, Team 15-5, Remmell Fall 2014crwdne2935289:0
USFT-REMMELL-F14S15G5
crwdns2942667:0crwdne2942667:0 3,293
