LG Optimus F3 Charging port unit Replacement
  1. LG Optimus F3 Charging port unit  Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the device so that the back faces up.
    • It is easiest to open the case near the charging port located at the bottom of the phone.
    • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
  2. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With back case removed, the battery is visible. The battery is the large square object.
    • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
  3. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 10 1.0 mm screws located on the back of the device.
    • Refer to the outlined locations in the image for the screws.
  4. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to separate the inner case from the device.
    • Wedge the plastic opening tool between the case.
    • Wiggle the tool and use leverage to pry the case apart.
  5. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
    • Use the plastic opening tool to separate the camera from the motherboard.
    • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
  6. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to disconnect and remove the rear facing camera.
  7. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
    • Note that the sim card and the memory card connector are one unit.
    • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
  8. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the charging port unit.
    • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
  9. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
    • The motherboard is an L-shaped unit above and to the left of the battery encasement.
    • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
  10. LG Optimus F3 Charging port unit  Replacement, Charging port unit: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove one 1.0 mm screw.
  11. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to remove front glass protector.
  12. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
  13. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the front facing camera.
  14. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
  15. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  16. LG Optimus F3 Charging port unit  Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You are all set.
Jonathan Fang
crwdns2935283:010/28/15crwdne2935283:0
356 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-5, Miles Fall 2015 crwdns2935289:0UMass Dartmouth, Team 1-5, Miles Fall 2015crwdne2935289:0
UMASSD-MILES-F15S1G5
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 657
