LG Optimus 3D Rear Camera Replacement
  1. LG Optimus 3D Rear Camera Replacement, Back Cover Removal: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Back Cover Removal: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  2. LG Optimus 3D Rear Camera Replacement, Battery Removal: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Battery Removal: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Battery Removal: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
  3. LG Optimus 3D Rear Camera Replacement, Screw Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Screw Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove 9 screws from the phone. The locations of these screws are circled in the picture.
    • 5.5mm length PH00 screws
    • 4mm length PH00 screws
  4. LG Optimus 3D Rear Camera Replacement, Bottom Cover Removal: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Bottom Cover Removal: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull down on the bottom cover to remove it.
  5. LG Optimus 3D Rear Camera Replacement, Mid-Cover Bezel Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Mid-Cover Bezel Removal: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Mid-Cover Bezel Removal: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a plastic opening tool, gently pry around the perimeter of the device.
    • The ribbons behind the buttons and ports are very delicate. Make sure you do not run your plastic opening tool too deep into the bezel, as you could damage them.
    • The button covers rest under the Mid-Cover Bezel. Remove them and set aside.
  6. LG Optimus 3D Rear Camera Replacement, Ribbon Cable Disconnection: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Ribbon Cable Disconnection: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a spudger or plastic opening tool, gently disconnect the ribbon cable attached to the black SIM card board.
  7. LG Optimus 3D Rear Camera Replacement, Adhesive Loosening: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a hair-dryer on high, or a heat-gun on low to heat the device and loosen the adhesive which holds down the SD/SIM Card Board.
    • Evenly heat the device in short intervals for about one minute.
    • Do not heat the device for more than 30 seconds at a time to prevent over-heating.
  8. LG Optimus 3D Rear Camera Replacement, SD/SIM Card Board Removal: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, SD/SIM Card Board Removal: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, SD/SIM Card Board Removal: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently pry the board up to release it from the now soft adhesive. Make sure you pry up the little tab connected to the camera unit as well.
    • If the board is too difficult to separate than more heating may be required.
  9. LG Optimus 3D Rear Camera Replacement, Heat Adhesive: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Heat the camera assembly in 20-30 seconds intervals with a heat gun set on low, or a hair drying set on high.
    • Although the motherboard assembly has been removed in the picture, it is not necessary to remove it for camera removal.
  10. LG Optimus 3D Rear Camera Replacement, Remove Camera Assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Optimus 3D Rear Camera Replacement, Remove Camera Assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using tweezers or a pry tool, gently wiggle and lift the camera assembly away from the body of the phone.
    • Although the motherboard has been removed in the pictures, it is not necessary to remove it before removing the camera.
Dale Pearson
crwdns2935283:009/22/14crwdne2935283:0
784 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 10-6, Brown Fall 2014 crwdns2935289:0USF Tampa, Team 10-6, Brown Fall 2014crwdne2935289:0
USFT-BROWN-F14S10G6
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 407
