Is your LG Neon GT 365 screen cracked, unresponsive, or displaying glitches? If so, you’re not alone. Screen damage is one of the most common phone issues, often caused by accidental drops or impact. This guide is here to help you fix these problems on your own, saving time and money on professional repairs.
By replacing the screen, you'll likely resolve issues such as touch sensitivity problems, display glitches, dead pixels, or complete unresponsiveness.
Place your phone upside down on a flat surface.
Using your other hand, stabilize the phone and press the rectangular button located on the top.
Using the same hand you pressed the button with, remove the rear cover.
Using the appropriate drill/screwdriver bit unscrew the small black screws securing the back cover and internal components.
A screw may be covered by the slide spring. If so, move the slide spring to the side to access the screw.
Use the iFixit opening tool to go around the seam of the phone and slowly pull off the slide panel.
Make sure the ribbon connector does not get caught.
First, remove the connector ribbon attached near the bottom of the phone. Just like when disconnecting the first end, this end is also removed by popping it off.
Carefully peel the three pieces of tape of the phone. The first two pieces of tape are green located at the bottom left and bottom right of the phone.
Hold the horizontal copper ribbon down with 2 fingers on each side of the tape.
Then carefully peel off the golden piece of tape circled, without ripping or damaging the copper ribbon
Carefully, disconnect the copper-colored ribbon.
Go around and under the silver LCD, essentially breaking its seal.
Then, use the popping tool to carefully lift the silver screen.
Once the silver LCD has been lifted up slightly slide the bottom half of the green circuit board off the phone by pulling down on it.
After the green circuit board has been removed you will be able to pop the screen out.
Grab a new screen and slide it in to replace it!
Follow the instructions in reverse to reassemble the phone with your new screen.
To reassemble your device, follow these instructions in reverse.
