This guide will assist you in removing and replacing the display panel on your LG Muziq.
Use a spudger to remove the two screw covers below display.
Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
Note: Side buttons may fall out when removing the front case. Do not misplace them.
Note: Each side button will only fit in the side that it came from.
Insert a spudger between the black and grey casings and gently spread them apart.
Work around the device gradually, opening the gap further.
Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
Carefully remove any parts stuck to the front case such as speakers.
Use the spudger to unclip the two upper wiring connections.
Gently lift the side buttons from the phone casing.
Use the spudger to remove the three components connected to the ribbon.
Use the spudger to gently remove the ribbon from the phone.
Use the spudger to lift the upper tab in the top left corner of the display.
Continue lifting until the display panels lift out of their setting and can be removed.
