Use this guide to remove the speakers from the device.
Use the spudger to pry out the indicated rubber squares.
Use the #0 Phillips screwdriver to take out the revealed screws.
Carefully lodge the spudger between the face plate and the hinge mechanism.
Gently pry the face plate until it releases from place holders.
Using a spudger, detach the speakers from their place holders.
Using the spudger, pry between the speaker circuit board and base to detach with ease.
