LG LD-2131SH Dishwasher Drain Pump Replacement
  1. LG LD-2131SH Dishwasher Drain Pump Replacement, Identify Machine and Drain Pump: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Identify Machine and Drain Pump: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Identify Machine and Drain Pump: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  2. LG LD-2131SH Dishwasher Drain Pump Replacement, Tools: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The main tools ( forgot to put the zip tie and clipper there, sorry :P )
    • NOTE: make notes of where screws are removed. I have gotten mixed up and spent many hours trying to sort them out - with poor success rate thus far :(
    • Make sure the machine is unplugged/disconnected from Electrical energy source before commencing!
    • Also remember to shut off and disconnect the water supply and drain hose :)
  3. LG LD-2131SH Dishwasher Drain Pump Replacement, Interior: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Interior: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove and un-clip the regular maintenance parts from interior.
    • Red circle: Also remove the vent plug on the side.
    • Hand Safety: Machine has stamped metal parts - take care not to cut yourself!
  4. LG LD-2131SH Dishwasher Drain Pump Replacement, Tub/Sub flange: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Tub/Sub flange: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Tub/Sub flange: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1st pic: remove the 4 screws that retain the discharge manifold (grey part).
    • 2nd pic: remove the clips that clamp the machine drum to the sub-assembly.
  5. LG LD-2131SH Dishwasher Drain Pump Replacement, Door: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Door: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now we disassemble the door. There are 10 screws around the circumference of the door, holding the front panel to the inside panel of the door. Remove them. (sorry I have lost the proper picture)
    • Make a note of where what wires go, and undo the harness.
    • Door front panel is separated, clean and set aside.
    • NOTE: there is a plastic shroud below the door - it unclips easily - remove that too.
  6. LG LD-2131SH Dishwasher Drain Pump Replacement, Top panel: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew indicated screws and slide top of machine towards the back, clean and set aside.
  7. LG LD-2131SH Dishwasher Drain Pump Replacement, Side panels: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Side panels: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Side panels: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Undo all the screws holding the two side panels in place.
    • Both panels remained hanging there after all the screws were out, which makes for easy work, thanks random engineer at LG!
    • Anyways, lift panels off, clean and set aside.
  8. LG LD-2131SH Dishwasher Drain Pump Replacement, Ballast Weight: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • I removed the ballast weight to ease handling of the tub.
  9. LG LD-2131SH Dishwasher Drain Pump Replacement, Tub/Sub separation: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Tub/Sub separation: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Tub/Sub separation: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Here we go at separating the tub from the sub-assembly. Remove screws as shown.
    • Red arrows: screws
    • Yellow arrows: screws on front side of machine
    • Green arrows: Earth Wires
    • Get someone to assist with lifting the tub off very carefully, while constantly checking for any snags etc. Once tub is removed, clean and set aside.
  10. LG LD-2131SH Dishwasher Drain Pump Replacement, Unhooking the Sub-assembly: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Unhooking the Sub-assembly: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Unhooking the Sub-assembly: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Red arrows: screws - the screw holding the harness-guide in place is accessed from the front of the machine.
    • Green arrows: unplug/disconnect
    • Purple circle: clip the zip tie
    • Green circle: next photo
    • Yellow arrows: flow sensors - they unclip from the housing or if you rather don't want to - they also have small connectors that you can unplug.
    • Light Blue circle: pull the pipes out from the housing - it is quite hard, but slow and steady wins the race. Wiggling helps too.
    • Dark Blue circles: undo the clips using pliers. I just moved the clips about an inch up the hose, easy storage spot. Then just wiggle the hoses off.
    • Carefully remove the harness, clean and set aside.
  11. LG LD-2131SH Dishwasher Drain Pump Replacement, Removal of component assemblies: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Removal of component assemblies: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Removal of component assemblies: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • 1st pic: circles show where I had my hands when lifting the salt bucket and water manifold out.
    • 2nd pic: arrow points to the rubber foot that we need to wiggle free when lifting the plumbing assembly out of the frame.
    • 3rd pic: Again position of my hands when pry-lifting the assembly out.
    • Please take care not to spill too much of the "grey water" trapped in the assembly onto anything you would not want it on.
  12. LG LD-2131SH Dishwasher Drain Pump Replacement, Pump Removal: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Pump Removal: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • 1st pic: Undo the screws and pull pump out of housing.
    • 2nd pic: I just flipped the pump over to show the impeller.
    • NOTE: This is the second DE failure. The first time around I found a small magnet stuck in the pump. No idea where it came from though. And also I assume it caused some unseen damage(more on this later).
    • DO NOT DO THIS - ELECTRICAL HAZARD
    • Testing revealed fluctuating vibrations, kind of like "speed wobbles", indicating well worn bush(es).
    • This can point to the rotor being forced out of line(alignment) while being mechanically stuck(the small magnet of earlier). Judging by the soft appearance of the bush(no pic sorry), I would give this theory a solid "most likely".
    • Prying the rotor from the housing reveals nothing further of concern. The water inside may actually provide some cooling assistance, and through the pumps design (Magnetic Drive), poses no electrical risk. This also removes the need for a shaft seal. Sound Engineering!
    • The video clip is a "super slo-mo" shot with a Samsung Galaxy S20FE. It shows the speeding up and slowing down of the pump. If I take the noise it makes into consideration, this is not normal. *I may obviously be wrong*
  13. LG LD-2131SH Dishwasher Drain Pump Replacement, Testing (pics): crwdns2935265:014crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Testing (pics): crwdns2935265:014crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Testing (pics): crwdns2935265:014crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Added this step to add pictures that relate to Step 13.
    • Electrical Hazard: Testing these things obviously need some know-how.
    • ELECTRICITY CAN KILL YOU
  14. LG LD-2131SH Dishwasher Drain Pump Replacement, Assembly: crwdns2935265:015crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Assembly: crwdns2935265:015crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG LD-2131SH Dishwasher Drain Pump Replacement, Assembly: crwdns2935265:015crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The assembly should be the reverse of what we have done. However, I will update with any significant findings, if any occur, once I have the new pump and start assembling.
♪♫KILLBILLY♫♪
crwdns2935283:007/29/20crwdne2935283:0
241 crwdns2915208:0crwdne2915208:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 2,335
