LG L1200 Logic Board Replacement
  1. LG L1200 Logic Board Replacement, Logic Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  2. LG L1200 Logic Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  3. LG L1200 Logic Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  4. LG L1200 Logic Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  5. LG L1200 Logic Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to disconnect antenna wire.
  6. LG L1200 Logic Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the IPod opening tool to pop out the logic board.
  7. LG L1200 Logic Board Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the IPod opening tool to disconnect the main ribbon.
  8. LG L1200 Logic Board Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the ribbon is detached, remove the logic board and replace if necessary.
Joshua Herrmann
crwdns2935283:004/16/10crwdne2935283:0
8 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-14, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 6-14, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S6G14
crwdns2942667:0crwdne2942667:0 1,258
