This guide will help you replace the keypad of the phone.
Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
Use IPod opening tool to separate back housing.
Separate the back housing from the phone.
Use a spudger to disconnect antenna wire.
Use the IPod opening tool to pop out the logic board.
Use the IPod opening tool to disconnect the main ribbon.
Once the ribbon is detached, remove the logic board and replace if necessary.
The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
Using a spudger, lift the keypad off of the tabs.
