LG L1200 External Housing Replacement
    1. LG L1200 External Housing Replacement, Inner LCD Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
      • Flip open the phone and locate the four screw covers.
    2. LG L1200 External Housing Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
    3. LG L1200 External Housing Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a T6 Torx screwdriver, remove all four screws.
    4. LG L1200 External Housing Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
      • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
    5. LG L1200 External Housing Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the inner screen cover towards you and up in order to separate it from the front cover.
    6. LG L1200 External Housing Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the tape from the bottom of the LCD screen.
    7. LG L1200 External Housing Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
    8. LG L1200 External Housing Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Flip the screen over so that you can see the outer LCD screen and the circuit board.
      • Insert spudger in the bottom right corner.
      • Lift up and move the spudger across the bottom.
      • The third photo is rotated 180 degrees.
    9. LG L1200 External Housing Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the pointy side of the spudger to peel off the interior tape.
      • Flip the assembly over and peel the circuit board from the screen.
    10. LG L1200 External Housing Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use the spudger to remove the LCD screen from its backing.
    1. LG L1200 External Housing Replacement, Camera: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
    2. LG L1200 External Housing Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
    1. LG L1200 External Housing Replacement, Logic Board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
    2. LG L1200 External Housing Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
    3. LG L1200 External Housing Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use IPod opening tool to separate back housing.
      • There are two tabs located on either side of the phone.
    4. LG L1200 External Housing Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Separate the back housing from the phone.
      • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
    5. LG L1200 External Housing Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a spudger to disconnect antenna wire.
    6. LG L1200 External Housing Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the IPod opening tool to pop out the logic board.
    7. LG L1200 External Housing Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the IPod opening tool to disconnect the main ribbon.
    8. LG L1200 External Housing Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the ribbon is detached, remove the logic board and replace if necessary.
    1. LG L1200 External Housing Replacement, Keypad: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
    2. LG L1200 External Housing Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using a spudger, lift the keypad off of the tabs.
    1. LG L1200 External Housing Replacement, External Housing: crwdns2935265:023crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Wedge a spudger or another harder prying tool in the connection between the top cover and the bottom cover on the right side.
      • Use a large amount of force to push the top cover off the bottom cover's blue extrusion.
      • Too much force may break the plastic of the top cover
      • When separating the top cover from the bottom cover, be careful not to tear the ribbon as you pull it out from the hinge.
    2. LG L1200 External Housing Replacement: crwdns2935265:024crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG L1200 External Housing Replacement: crwdns2935265:024crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Slide the ribbon out of the slot in the joint on the left side.
      • Pull the ribbon out of the top cover with your hand.
      • Once the ribbon is removed, you can replace the covers.
Joshua Herrmann
crwdns2935283:004/16/10crwdne2935283:0
8 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 6-14, Maness Spring 2010 crwdns2935289:0Cal Poly, Team 6-14, Maness Spring 2010crwdne2935289:0
CPSU-MANESS-S10S6G14
crwdns2935297:096crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,590
