crwdns2959928:0crwdne2959928:0 ↓Remove the battery before removing the back controls to avoid electric shock. Do not lose any screws or the middle button of the back controls.
Flip the LG K7 over so that the back of the phone is facing up.
Locate the small notch on the bottom left side of the phone.
Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
Locate the screw keeping the back controls in place.
Use a Phillips 00 screwdriver to remove the 3.4 mm screw.
Using the plastic opening tool create a space between the chrome bezel of the back buttons and the phone's casing.
Using the plastic opening tool pry the back buttons upward to remove them from the phone's casing.
