crwdns2959928:0crwdne2959928:0 ↓The home button cable connects the home button to the rest of the phone. It can stop working for a number of reasons but the main two are shock and wear. It can be replaced in less than 5 minutes with the guide below.
Place a fingernail in slot at in the bottom edge of the phone.
Pull up on the back panel while holding down the rest of the phone steady with your hand.
Place a fingernail in the slot at the bottom edge of the battery.
Pull the battery out.
Remove the nine frame screws with a JIS #00 screwdriver.
Pop the camera button frame off with a spudger. The home button should come off along with the frame.
Use a plastic opening tool to separate the screen from the outer frame.
The home button cable is attached to both the front and the back of the outer frame with adhesive. Orient the frame so that where the screen would be is facing you. Peel back the black rubber tab covering the wire.
Detach the cable from the frame with a plastic opening tool and let hang.
Flip the phone over and detach the button sensor part of the cable from the frame with a spudger.
Pull the backside cable through the hole when removing the component.
