LG K40S Fingerprint Scanner Replacement
  1. LG K40S Fingerprint Scanner Replacement, Precautions: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Precautions: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Precautions: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your phone by holding the power key, pressing power off, then confirm.
    • Make sure that the battery of your phone is below 25% before opening to avoid battery fires should an accident happen.
  2. LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Removing SIM & SD Card trays: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a SIM Eject tool (real one, bent paperclip or otherwise) to eject the 2 SIM & SD Card trays before removing them from the phone.
  3. LG K40S Fingerprint Scanner Replacement, Removing back panel: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Removing back panel: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Removing back panel: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The back panel is made of plastic significantly reducing the chance of breakage compared to a glass back.
    • The back panel is held on with plastic clips and can be unclipped using plastic picks.
    • Be careful around the buttons so as to not damage the flex cables they reside on. The buttons on the back panel are seperate from the flex cable containing the buttons
    • Do not fully pull the back panel off straight away, you may rip the flex cable for the fingerprint scanner.
  4. LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Disconnecting fingerprint scanner: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the back panel to the right as shown in image 1.
    • Disconnect the fingerprint scanner flex cable using a plastic pick or spudger
    • Pull the back panel away from the phone.
  5. LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG K40S Fingerprint Scanner Replacement, Removing fingerprint scanner from back panel: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the black tape covering the fingerprint scanner using your fingers or a plastic pick, being careful not to insert your pick too far if using one.
    • Carefully push the fingerprint scanner through the back panel.
    • Use a plastic pick to carefully unadhere the flex cable from the back panel.
    • Pull the fingerprint sensor away from the back panel.
JoshAtticus
crwdns2935283:004/08/23crwdne2935283:0
275 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 183
