LG K20 PLUS Motherboard Removal
  1. LG K20 PLUS Motherboard Removal, Remove the back cover and battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG K20 PLUS Motherboard Removal, Remove the back cover and battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Motherboard Removal, Midframe: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove 11 Philips screws.
  3. LG K20 PLUS Motherboard Removal: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG K20 PLUS Motherboard Removal: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Motherboard Removal, Rear-Facing Camera: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    Halberd Spudger
    $2.99
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. LG K20 PLUS Motherboard Removal, Motherboard Removal: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
Patrick
crwdns2935283:005/14/14crwdne2935283:0
6,764 crwdns2915208:0crwdne2915208:0
crwdns2935297:021crwdne2935297:0
crwdns2942667:0crwdne2942667:0 929
