LG GW910 Camera Replacement
  1. LG GW910 Camera Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG GW910 Camera Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. LG GW910 Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG GW910 Camera Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the battery by lifting from the bottom.
  3. LG GW910 Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove six 3mm PH000 screws.
  4. LG GW910 Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG GW910 Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG GW910 Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. LG GW910 Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. LG GW910 Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. LG GW910 Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG GW910 Camera Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG GW910 Camera Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
  8. LG GW910 Camera Replacement, Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG GW910 Camera Replacement, Camera: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the connector using the metal spudger.
    • Peel back the tape on the side.
    • Replacement tape might be needed.
  9. LG GW910 Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG GW910 Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG GW910 Camera Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pry open the two plastic hooks using the metal spudger tool.
    • Crack open the black plastic cover using the metal spudger tool. The cover should be easily turned over.
    • The connector might get stuck in the opening while turning over the cover. Twist the connector if needed.
  10. LG GW910 Camera Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG GW910 Camera Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the camera unit by prying on it.
    • Adhesive will be needed for reassembly.
Jonas Ke
crwdns2935283:011/06/18crwdne2935283:0
492 crwdns2915208:0crwdne2915208:0
IUPUI, Team S1-G6, Hovde Fall 2018 crwdns2935289:0IUPUI, Team S1-G6, Hovde Fall 2018crwdne2935289:0
IUPUI-HOVDE-F18S1G6
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 186
