LG G8 ThinQ Battery Replacement
  1. LG G8 ThinQ Battery Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Battery Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Back Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Battery Replacement, Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Midframe: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Midframe: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Battery Replacement, Speaker System: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Speaker System: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Speaker System: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip phone so that screen is facing up.
    • Using a heating pad, hairdryer, or heat gun, apply heat to loosen the adhesive beneath the battery.
    • Be careful to not overheat the phone; the screen and battery are susceptible to damage.
    • The adhesive can be difficult to soften; it may take many attempts.
  6. LG G8 ThinQ Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G8 ThinQ Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening tool, carefully pry up the ribbon cable to disconnect the battery.
  7. LG G8 ThinQ Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using opening cards or an opening tool, carefully pry around the edges of the battery.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. Re-apply heat, or use some isopropyl alcohol under the battery, allowing it to penetrate for several minutes to weaken the adhesive.
    • Remove the battery from the phone.
Lauren Maynor
crwdns2935283:009/17/21crwdne2935283:0
115 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-4, Virtue Fall 2021 crwdns2935289:0Western Carolina University, Team 1-4, Virtue Fall 2021crwdne2935289:0
WCU-VIRTUE-F21S1G4
You don't use any heat to remove the back glass panel? Just suction cup and prying?
CarnalT - crwdns2934203:0crwdne2934203:0
Yep need heat to remove the back. Glass shattered on mine. Ifixit needs to fix this guide.
Bryan Ransom - crwdns2934203:0crwdne2934203:0
Success! I documented the process using ifixit tools on https://waynedavis.com
Wayne Davis - crwdns2934203:0crwdne2934203:0
thanks for your tutorial man it helped me a lot
John Eric Limbago -
Very helpful tutorials guys. Im in need of replacing my battery in my g8. 2 questions. Do you need to remove the speaker component at the bottom left in order to replace the battery? Some videos i watched they didnt remove it. 2nd question is how to i get the back cover back on after replacing the battery? Is there a specific adhesive i can get?
Johnny XRay - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 13
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 153
crwdns2942667:0crwdne2942667:0 11,167
