LG G8 ThinQ Battery Replacement
  1. LG G8 ThinQ Battery Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, SIM Card Tray: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Battery Replacement, Back Panel: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Back Panel: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Back Panel: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
    This is where I started to ponder for the first time because my camera looks different.
    I also have a LG G8 ThinQ but maybe the european version
    Thomas Wiele - crwdns2934203:0crwdne2934203:0
  3. LG G8 ThinQ Battery Replacement, Midframe: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Midframe: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Midframe: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
    and here it is true, the screws are in a different place. The sound system on the bottom is also different
  4. LG G8 ThinQ Battery Replacement, Speaker System: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Speaker System: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement, Speaker System: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
  5. LG G8 ThinQ Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip phone so that screen is facing up.
    • Using a heating pad, hairdryer, or heat gun, apply heat to loosen the adhesive beneath the battery.
    • Be careful to not overheat the phone; the screen and battery are susceptible to damage.
    • The adhesive can be difficult to soften; it may take many attempts.
  6. LG G8 ThinQ Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G8 ThinQ Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using an opening tool, carefully pry up the ribbon cable to disconnect the battery.
    the battery type of my LG is "BL-T43"
  7. LG G8 ThinQ Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G8 ThinQ Battery Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using opening cards or an opening tool, carefully pry around the edges of the battery.
    • If you have trouble prying up the battery, the adhesive may not be loose enough. Re-apply heat, or use some isopropyl alcohol under the battery, allowing it to penetrate for several minutes to weaken the adhesive.
    • Remove the battery from the phone.
    Although it is a different phone, the instructions were helpful.
    Unfortunately, my battery exchange was pointless.
    I think my USB socket is defective and unfortunately I can't find any instructions for it at the moment.
    But if anybody want, i can send a few pics from the repairing
Lauren Maynor
crwdns2935283:009/17/21crwdne2935283:0
115 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-4, Virtue Fall 2021 crwdns2935289:0Western Carolina University, Team 1-4, Virtue Fall 2021crwdne2935289:0
WCU-VIRTUE-F21S1G4
You don't use any heat to remove the back glass panel? Just suction cup and prying?
CarnalT - crwdns2934203:0crwdne2934203:0
Yep need heat to remove the back. Glass shattered on mine. Ifixit needs to fix this guide.
Bryan Ransom - crwdns2934203:0crwdne2934203:0
Success! I documented the process using ifixit tools on https://waynedavis.com
Wayne Davis - crwdns2934203:0crwdne2934203:0
thanks for your tutorial man it helped me a lot
John Eric Limbago -
Very helpful tutorials guys. Im in need of replacing my battery in my g8. 2 questions. Do you need to remove the speaker component at the bottom left in order to replace the battery? Some videos i watched they didnt remove it. 2nd question is how to i get the back cover back on after replacing the battery? Is there a specific adhesive i can get?
Johnny XRay - crwdns2934203:0crwdne2934203:0
This is basically exactly the same process to open the LG G7 ThinQ. Right: on the first time ever, use some source of heat or a hairdryer to soften the glue on the back. I have a few "ice/heat gel packs" and I heat on the microware. Put it 20-30 seconds interval (up to 2 minutes) to get a good amount of heat. Massage/squish the pack to mix the gel. Helps tremendously.
When a corner lifts, things get a lot easier - keep adding cards/guitar picks.
Now the battery itself is a major pita to get it loose. I'd recommend isopropyl alcohol as the guide mentions.
You can also use an old credit cart beveling an edge to try to pry the battery. Be patient.
I usually don't put glue back to hold the battery as the remainder of the old glue is enough. Have done it 3 times for my daughter's phone.
A little amount of glue with the kit, would be nice but since it stays in its case, the remainder of glue is also usually enough to keeps things close... no more waterproof seal though.
Alex De Lara - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 14
crwdns2936753:07crwdne2936753:0 46
crwdns2936753:030crwdne2936753:0 147
crwdns2942667:0crwdne2942667:0 11,171
