crwdns2959928:0crwdne2959928:0 ↓This guide will show you how to replace the Motherboard.
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
Detach the cover with your fingers
Remove the following four press-fit connectors with the flat edge of a plastic spudger or opening tool:
Front-facing camera connector.
Rear-facing camera connector.
Digitizer connector.
Remove the motherboard by lifting it up using the plastic opening tool and your fingers .
crwdns2935229:056crwdne2935229:0
crwdns2947412:025crwdne2947412:0
Where can I get a motherboard? I have been looking everywhere with no luck.
nellyquicksilver - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If you had it less then a year lg will send u a replacement but if your phone is damaged they will charge u just say it's not damage and swap the boards and send them the new one back so u won't be charged they won't notice I just did it
Alex - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
i have to ask did they ever notice with the swap???
mklb492 - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
If my phone has the boot loop problem and i change the board will mi picture still be there ??
josean ramos - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Did you find a resolution to this problem? I am facing the same thing!
Shahad Shihab - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
