LG G2 Battery Replacement
  1. LG G2 Battery Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, or the thin side of the spudger to separate the back cover from the phone. Start at the bottom corner of the phone. Be gentle because it may cause cosmetic and internal damage if not done with care.
  2. LG G2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With the back cover removed you will get a view like this.
    • Use the Phillips 00 screw driver to remove all visible screws. Try to organize the screws so there is no confusion when reassembling the phone.
    • 6 silver cross head phillips #1 4mm screws circled in red.
    • 5 gold cross head phillips #1 4mm screws circled in yellow.
    • 1 black cross head phillips #2 2mm screws circled in blue.
  3. LG G2 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G2 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After all visible screws have been removed use the spudger to pop off the top plastic cover.
  4. LG G2 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G2 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Do the same for the bottom plastic cover.
  5. LG G2 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G2 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G2 Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The motherboard should be full visible now.
    • Start loosening all the connectors to the motherboard with the pointy side of the spudger. Look at picture to make sure all connectors have been disconnected.
  6. LG G2 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G2 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After all connector are loosened up the motherboard should be free, but before removing it lets disconnect it a little further.
    • The flex cables running on the left and right side of the battery are connected to a smaller board connected which on their turn is connected with small amounts of adhesive materials to the motherboard. Use the spudger to carefully separate the smaller board of the motherboard.
  7. LG G2 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Make sure you pay attention when removing the left flex cable because it is also connected to the side. Simply just peal this part away also. It may be a little more difficult than the upper connections, but just peel away. It may bend a little but be careful not to break.
  8. LG G2 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • It may seem as if the flex cable are free to remove, but not yet. The two flex cable are both together at the bottom, and connected to a small control board. Therefore we need to remove the control board completely.
  9. LG G2 Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the 2 connectors. The LCD connector (red color coded) and the Digitizer (yellow color coded). Together with these 2, remove the 2 antenna connections (green color coded) also.
  10. LG G2 Battery Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G2 Battery Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The motherboard is also held down with some adhesive but carefully can be pried up. Make use of Spudger.
    • When motherboard is removed you will get a view like this.
crwdns2935229:018crwdne2935229:0
Marko Zrnic
crwdns2935283:009/23/14crwdne2935283:0
1,012 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-1, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-1, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G1
crwdns2947412:05crwdne2947412:0
You did not show how to remove the battery. You must tell the people every step and not lead them guessing. They might be trying this for the first time. I know that is how I did my first repair was follow the detailed instructions on IFIXIT and i was able to fix phones.
Here is a link that shows the removal step that you are missing.
LG G2 LCD and Digitizer Replacement
Darren - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Hey Darren! Sorry about the issues with the battery removal. This is an "Archived" guide, which means that it's only being kept around for reference, and really shouldn't be used unless absolutely necessary. We'll hopefully have a full set of guides for the LG G2 in the coming months, so stay tuned!
Geoff Wacker - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I really agree with Darren. For me the worst step was to unglued the battery. Why so much adhesive? It is no necessarily so...
Thanks Geoff!!!
Roman Santorcuato - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
What an utter waste of time. You should remove this guide from the site. The note at the top of the refers to another guide, but there is none. A note in the message section says there will be a guide in the coming months, but 7 months later there is not.
Poorly curated, and misleading.
Gerard P - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I think in Step 5 it isn't necessary to remove all of the connectors. You really only need to remove 4 connectors in total... the 2 camera connectors, the proximity sensor and the longer one reaching down from the upper left corner (digitizer cable maybe?). That way you can just lift the motherboard up while still attached to the phone 90 degrees to access the battery. I had good luck with some heat and 3 spudgers to remove the battery, just be patient. Oh, and exploit the weak point under the battery cable to begin the battery/adhesive separation.
Damon - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:030crwdne2936753:0 78
crwdns2942667:0crwdne2942667:0 22,536
