LG G Watch R Motherboard Replacement
  1. LG G Watch R Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch R Motherboard Replacement, Back Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
    So i bought a torx t5…but it is tooo big. It must br torx t4
    Jetze Kooistra - crwdns2934203:0crwdne2934203:0
    I think I have damaged one of the screw heads while trying to unscrew the back of the watch.
    I used the Torx T4… but the screw was covered in quite a bit of rust. Now the Torx T4 can’t get a grip.
    What should I do? (Can anything be done?)
    John Maher - crwdns2934203:0crwdne2934203:0
    Yea take a tiny file or a tiny Dremel attachment and carve a flat head groove in the head just enough so where you can use a flat head to get it
    Andrew L rambeaut -
    Thank you for good instructions! Saved me for 300€ (don’t have to buy a new wacth) ?
    Ernst Kranke - crwdns2934203:0crwdne2934203:0
  2. LG G Watch R Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the back case.
  4. LG G Watch R Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch R Motherboard Replacement, Motherboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
    Where do I buy the parts? I already have your tools.
    Marco Roman - crwdns2934203:0crwdne2934203:0
  5. LG G Watch R Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch R Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
    Add colored markup to indicate location of the 3 screws.
    Patty Remmell - crwdns2934203:0crwdne2934203:0
    I felt like my #00 driver fit slightly better for these screws, but it probably depends on which toolkit or bit set you have.
    J Suo - crwdns2934203:0crwdne2934203:0
  6. LG G Watch R Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
Westley Courchene
crwdns2935283:001/13/15crwdne2935283:0
3,410 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 1-1, Remmell Fall 2015 crwdns2935289:0USF Tampa, Team 1-1, Remmell Fall 2015crwdne2935289:0
USFT-REMMELL-F15S1G1
Thanks for this! None of the other fixes worked, so I tried this as a last resort with a motherboard borrowed from another G Watch, and it did the trick. So now I know the motherboard was the problem.
H Arumph - crwdns2934203:0crwdne2934203:0
Where do I buy a replacement motherboard from??
Brandon Reznik - crwdns2934203:0crwdne2934203:0
Did you ever find anywhere to order a replacement motherboard?
Robert Dye -
crwdns2942667:0crwdne2942667:0 3,310
