The battery can be used to hold a charge that powers the watch for a period of time.
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
Use a plastic opening tool to pry open the back case from both sides of the watch.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
Use a plastic opening tool to pry the battery out of the device.
crwdns2935229:071crwdne2935229:0
crwdns2947412:013crwdne2947412:0
The question is where i can find such battery ?
obada abu alhiga - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
It did help, small correction - Use a T4 instead of T5 screw driver
Suyog Patki - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
On my G Watch R the T5 screw driver perfektly fits.
igor-sweet - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
I second the fonejoy link, got it delivered from them very quickly. And I also second what Suyog said regarding the Torx screwdriver, on my own watch I needed a T4, the T5 didn't work, but I had a set so I was okay.
Mike - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
