LG G Watch Display Assembly Replacement
  1. LG G Watch Display Assembly Replacement, Wristband: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Display Assembly Replacement, Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Display Assembly Replacement, Gasket: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
  6. LG G Watch Display Assembly Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Display Assembly Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to gently lift up and disconnect the display connector.
    • Now use the spudger to disconnect the digitizer connector.
  7. LG G Watch Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #000 screwdriver to remove the two black PHO 2.5mm x 3mm screws.
    • Use the spudger to gently remove the motherboard.
  8. LG G Watch Display Assembly Replacement, Removing the screen: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply a small amount of pressure to the back of the LCD to create a gap for the opening pick.
    • Gently work the pick around the perimeter of the device to loosen up the adhesive.
    • An iOpener may be necessary to help loosen up the adhesive. Refer to our iOpener guide for info on how to use it.
  9. LG G Watch Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After using the pick to loosen the adhesive, simply pull the display assembly up from the metal bezel.
Mandy McGarry
crwdns2935283:009/23/14crwdne2935283:0
165 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-5, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-5, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G5
Where can you purchase replacement parts?
Brian Winebarger - crwdns2934203:0crwdne2934203:0
Someone knows where to find a screen replacement?, i found at alibaba but i have to buy 1k ... :(
George Momo Seyssel - crwdns2934203:0crwdne2934203:0
I found a 00 screwdriver was better than 000 for removing the motherboard.
Peter Jeremy - crwdns2934203:0crwdne2934203:0
Be smart buy a used one for nuthin on eBay….
jeromedaues - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,526
