LG G Watch Battery Replacement
  1. LG G Watch Battery Replacement, Wristband: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Battery Replacement, Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
  5. LG G Watch Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Battery Replacement, Battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two black Phillips #000 2.5x3mm screws that are located on the right side of the metal clip.
  6. LG G Watch Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a pair of tweezers to gently lift the metal retaining clip up and out of the way.
  7. LG G Watch Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Watch Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently pry the battery up from the rear case.
    • The battery is attached with a small amount of adhesive, so some force may be required.
Deja Miller
crwdns2935283:010/14/14crwdne2935283:0
462 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 2-5, Blackwell Fall 2014 crwdns2935289:0USF Tampa, Team 2-5, Blackwell Fall 2014crwdne2935289:0
USFT-BLACKWELL-F14S2G5
Hello where can i buy the battery and the tools to perform this function. Also I love my lg watch and I get 3 days before needing a recharge but, i do not play with it and do not add all the fancy watch faces either. just look at text messages and see who is calling. I think its the best out there only draw back is the cradle charger. please email me. buckeybandit69@gmail.com.
thank you..
Brian Adams - crwdns2934203:0crwdne2934203:0
I know how to change but where can i buy the battery for this watch//
bikerdennis321 - crwdns2934203:0crwdne2934203:0
I had mine on eBay. Search for LG W100KT 400mAh Battery-BL-S1
It works perfectly till now.
MrPatate - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 46
crwdns2942667:0crwdne2942667:0 8,649
