If your LG G Pad F 8.0 isn’t powering on and can not be charged, use this guide to replace the battery.
The battery powers on the tablet. A faulty battery will not keep charge and stay dead until the battery is replaced.
Before using this guide, inspect the charging cable. Typically, a faulty charging cable can prevent the tablet to be charged.
Before beginning, make sure to power off your phone completely and disconnect from any external power source.
Place the tablet with the screen facing down.
Open the SIM port on the top right corner of the tablet.
Press the SIM card to pop it out.
Remove the SIM card from the tablet.
Use the iFixit opening tool to pry the back cover off of the tablet.
Work your way all the way around the edge of the screen, and remove the back cover when it is loose.
Disconnect the large, yellow ribbon using the iFixit opening tool.
Pry up on the multi-color ribbon with the iFixit opening tool to disconnect it.
Use the iFixit opening tool to pry up the four edges of the battery.
Remove the battery from the tablet.
