If your tablet isn't working properly, you may need to replace the motherboard. This guide will show you how to replace the motherboard.
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Insert a plastic opening tool in the small crevasse between the screen and the back panel.
Pry the screen away from the back panel.
Repeat this on each edge of the device.
After using the plastic opening tools, pry the device open with your hands.
Remove the back panel from the screen.
crwdns2935267:0crwdne2935267:0Magnetic Project Mat$19.95
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
Use your fingers to remove the speaker.
Remove the 3mm Phillips #000 screws from the corners of the battery.
Using a spudger or a plastic opening tool, disconnect the ribbon cable from the right side of the device.
Using the Phillips #000 screwdriver, remove the two 3mm screws located at the bottom of the ribbon cable.
Remove the ribbon cable from the device.
Unhook the battery from the top of the device.
Unhook the small yellow ribbon on top of the motherboard.
Remove all the 3mm silver screws and the 2mm black screws on the motherboard and carefully lift it out of the device.
Use a plastic opening tool to lift the motherboard out of the device.
crwdns2935229:08crwdne2935229:0
