With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
Take the spudger and slide it around the perimeter of the device.
Pull gently on the edges to get the panel to pop up.
Remove the 4 1.5 mm screws holding the speakers in place.
Put the spudger underneath the gold cap of the cable and lift to disconnect from device.
Pull the cable back and out of the way of the speaker.
Place the spudger in between the speaker and the device to pop the speaker out of place.
Pull the speaker out of the device.
