Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
Disconnect the battery connector by prying it upwards (red marker).
Remove the ribbon cables by prying them upwards with a plastic pry tool ).
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device.
Pry the audio jack from the device using a spudger.
Remove the 7 Black 3mm PH0 screws from the motherboard (red markers).
