In cases where the front facing camera is not responding or isn’t powering on, this guide will help you replace the camera to fix these issues.
Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
Disconnect the battery connector by prying it upwards (red marker).
Remove the ribbon cables by prying them upwards with a plastic pry tool ).
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device.
Pry the audio jack from the device using a spudger.
Remove the 7 Black 3mm PH0 screws from the motherboard (red markers).
Gently pull up on the camera to remove it.
