Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
Disconnect camera ribbon cable by prying up on it with a plastic pry tool.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers or a small plastic pry tool gently pull or pry the camera out of the device (red marker).
Install the new camera into device by gently placing it in its corresponding place until it pops in.
