In cases where the battery is not charging or the device isn’t powering on, this guide will help you replace the battery to fix these issues.
Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
crwdns2935267:0crwdne2935267:0Anti-Static Wrist Strap$7.95
To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
Disconnect the battery connector by prying it upwards (blue marker).
Remove the ribbon cable by prying it upwards (red marker).
There is a light adhesive holding the battery in the frame of the device. Gently pry the bottom the battery using a plastic pry tool.
crwdns2944067:04crwdne2944067:0
This tells me how to take out the battery. Any little tricks I need to know to put in a new one?
This is how I remove the battery. Any tricks to installing a new one?
No trick, follow instruction in reverse substituting the new battery and you’ll be golden.
Thanks so far, but when the back has been separated it does not look like yours. Can you enlighten me on how to remove the 2nd black plastic layer that covers the battery and circuit boards so I can access the battery? My email is atschramm1@outlook.com
