LG G Pad 7.0 Battery Replacement
  1. LG G Pad 7.0 Battery Replacement, Front Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG G Pad 7.0 Battery Replacement, Front Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The screen assembly is secured to the plastic backing with clips. Insert the spudger between the screen and plastic.
    • Work your way around the device, freeing it from the connecting clips.
    • Be careful around the MicroSD, sim card, power, and volume buttons
    • Attempt to lift the tablet from the plastic frame. You may need to loosen some more clips if it is difficult to remove.
  2. LG G Pad 7.0 Battery Replacement, Battery Connector: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG G Pad 7.0 Battery Replacement, Battery Connector: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG G Pad 7.0 Battery Replacement, Battery Connector: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery connector marked in orange, by prying it upwards.You may need some force to do this, be careful not to damage anything.
    • Remove the other connector marked in red by gently prying up. Be sure not to rip the ribbon cables as they are very fragile.
  3. LG G Pad 7.0 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pry the battery up making sure not to bend it or snag any cables.
    • The battery is secured by two pieces of double sided tape on the left and right edges under the battery.
    PERFECT instructions, Thanx.
    Now to find a new battery.
    D.A. Pawley - crwdns2934203:0crwdne2934203:0
crwdns2935229:019crwdne2935229:0
echow2001
crwdns2935283:009/05/15crwdne2935283:0
2 158 crwdns2915208:0crwdne2915208:0
Thank you for this guide. The iFixit tool worked much better than the one that came with the replacement battery. I needed a magnifying glass to verify I lined up the ribbon cable connector but other than that it went smoothly.
Juan Campos - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 17,611
