Signs you might need this replacement:
- Tablet doesn't charge
- May be caused by faulty battery
- Tablet charges slowly
- May be caused by fault battery
crwdns2935267:0crwdne2935267:0SIM Card Eject Tool$2.99
Insert your Sim Card Eject Tool into the SIM tray hole and pull out the SIM tray
Remove the screws at the buttom (near the charging port) with your T2 Torx Screwdriver
crwdns2935267:0crwdne2935267:0iFixit Opening Picks (Set of 6)$4.99
Use your opening picks to loosen the back plate and lift it from the tablet.
Disconnect the fingerprint wire to remove the back plate fully.
crwdns2935267:0crwdne2935267:0Phillips #00 Screwdriver$5.49
Unscrew and remove the right panel using your Phillips #00 Screwdriver
Using your Phillips #00 Screwdriver, unscrew and remove the left panel.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, remove the charging port board
Insert your new port
The back plate should pop back on very easily.
