Installing the Number Keypad and the LCD Screen can be done at the same time. Note, however, that the Keypad and the hardware casing are connected and must be installed together.
Place the phone so the screen side is facing down.
Locate the latch at the end of the phone, opposite of the camera.
Push/pull the latch away from the camera, causing the battery to pop out.
Remove the 5 screw covers on the back of the phone using a Push Pin.
With a Phillips #00 Screwdriver, remove the five 3.44 mm screws that were under the screw covers.
Also with a Phillips #00 Screwdriver, remove the screw that was revealed once the battery was removed.
Starting at the card slot or charger port for greater ease, pry off the colored casing from the back of the phone using the Plastic Pry Tool (or a finger nail may work).
Remove the back colored casing and set it to the side.
Gently pry and detach the connection located near the hinge with fingers.
Lift them both out from the rest of the phone.
After removing the circuit board and key board, separate the top part with the screen from the bottom part by detaching the hinges.
Remove the 4 screw covers from top piece of phone by using a Push Pin.
Remove the four 3.44 mm screws that were under the covers using a Phillips #00 Screwdriver.
Pry open the colored casing using the Plastic Pry Tool.
Remove the number pad and place it to the side.
Because the Number Keypad is attached on one side and on top of the outer screen, open its metal casing, in a "door-opening" manner.
The Number Keypad and its metal casing are attached to the clear plastic screen that the LCD Screen was in. Replace both the Keypad and the casing as a unit.
