LG EnV Touch VX11000 Screen Assembly Replacement
  1. LG EnV Touch VX11000 Screen Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the phone off.
    • Flip it over so the front screen is facing down.
  2. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the release latch down and toward you while lifting up on the left side of the battery cover.
  3. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the edge of the battery to remove it.
  4. LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement, Volume and Camera Buttons: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
    • Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
  5. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
  6. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool or your fingernail to pry off the back case.
    • The camera and volume keys will fall off.
  7. LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement, Screen Assembly: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Open the phone at a 90 degree angle. This needs to be done in order to reach the screws.
    • Locate the two 1.5mm #000 Phillips screws on the outside of each hinge.
    • Remove the two 1.5mm #000 Phillips screws with a Phillips #000 screwdriver.
  8. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the two screw covers on the inside screen, using a spudger or your fingernail.
    • Remove the two 1.5mm #000 Phillips screws that were under the screw covers using the Phillips #000 screwdriver.
  9. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the front frame using your fingernail.
    • The frame should still be connected to the rest of the phone by the orange tab.
  10. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 1.5mm #000 Phillips screws at each of the corners of the phone, using the Phillips #000 screwdriver.
  11. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Peel off the gold tape.
    • Gently pry up the metal frame with your fingers so that the screen can be removed.
  12. LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG EnV Touch VX11000 Screen Assembly Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unplug the connector from the screen.
Rachel Smith
crwdns2935283:009/30/13crwdne2935283:0
593 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-2, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 13-2, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S13G2
crwdns2942667:0crwdne2942667:0 1,283
