LG Cosmos Silicon Keypad Replacement
  1. LG Cosmos Silicon Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Silicon Keypad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Silicon Keypad Replacement, Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Silicon Keypad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Silicon Keypad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Silicon Keypad Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Silicon Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Silicon Keypad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Silicon Keypad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Silicon Keypad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Silicon Keypad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the motherboard away from the rest of the phone.
  12. LG Cosmos Silicon Keypad Replacement, Silicon Keypad: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the silicon keypad away from the rest of the phone.
Johnny Phane
crwdns2935283:004/15/13crwdne2935283:0
91 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-63, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-63, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G63
Steps 10 and 11 are not necessary for replacing just the silicone keypad. As long as you are careful not to pull on the motherboard, once you have the motherboard rotated up, you are able to replace the silicone keypad directly from that point.
Randy - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 898
