LG Cosmos Side Case Replacement
  1. LG Cosmos Side Case Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Apply an upward force to slide the back cover off.
  2. LG Cosmos Side Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to push down on the top of the battery and pull it out.
  3. LG Cosmos Side Case Replacement, Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
  4. LG Cosmos Side Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic opening tool to pry the rear case loose.
  5. LG Cosmos Side Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the rear case is loose, lift it from the rest of the phone.
  6. LG Cosmos Side Case Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
  7. LG Cosmos Side Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to pry the motherboard loose.
  8. LG Cosmos Side Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
    • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
  9. LG Cosmos Side Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
  10. LG Cosmos Side Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to pull the flex cable out from its connector.
  11. LG Cosmos Side Case Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the motherboard away from the rest of the phone.
  12. LG Cosmos Side Case Replacement, Silicon Keypad: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the silicon keypad away from the rest of the phone.
  13. LG Cosmos Side Case Replacement, Side Case: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 2.0mm Phillips #000 screws on the golden squares.
  14. LG Cosmos Side Case Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the side case away from the rest of the phone.
    • The flex cable can be torn if it is caught on the frame of the side case.
Johnny Phane
crwdns2935283:004/15/13crwdne2935283:0
91 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-63, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-63, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G63
crwdns2942667:0crwdne2942667:0 1,103
