crwdns2959928:0crwdne2959928:0 ↓If you have damaged your side case, it is possible to replace. It requires time, a lot of disassembling, and includes many small parts.
Apply an upward force to slide the back cover off.
Use your finger to push down on the top of the battery and pull it out.
Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
Use a plastic opening tool to pry the rear case loose.
Once the rear case is loose, lift it from the rest of the phone.
Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
Use the plastic opening tool to pry the motherboard loose.
Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
Use your finger to pull the flex cable out from its connector.
Pull the motherboard away from the rest of the phone.
Lift the silicon keypad away from the rest of the phone.
Remove the four 2.0mm Phillips #000 screws on the golden squares.
Slowly lift the side case away from the rest of the phone.
