LG Cosmos Motherboard Replacement
crwdns2869540:0crwdne2869540:0: 2,4 B
20
76
2.422
crwdns2959984:0crwdne2959984:0: 1
crwdns2959972:01crwdne2959972:0
crwdns2955944:0crwdne2955944:0: 30 - 35 crwdns2931279:0crwdne2931279:0
Use this guide to replace a faulty or dead motherboard in the LG Cosmos.
The motherboard is an essential device component, connecting all its parts. The keyboard, screen, and speakers are all connected via the motherboard. Input errors, screen malfunctions, or sound issues can be symptoms of the motherboard.
If you encounter any complications, consult the troubleshooting guide for help. These issues can be the individual parts themselves.
Be careful when dismantling the device. Ensure the battery is not damaged, and avoid rushing through the guide. Take your time when dealing with the cables inside the device.
    1. LG Cosmos Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Apply an upward force to slide the back cover off.
    2. LG Cosmos Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your finger to push down on the top of the battery and pull it out.
    1. LG Cosmos Motherboard Replacement, Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the five 3.0mm Phillips #000 screws along the edge of the rear case.
    2. LG Cosmos Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use a plastic opening tool to pry the rear case loose.
    3. LG Cosmos Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the rear case is loose, lift it from the rest of the phone.
    1. LG Cosmos Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the two 2.9 mm Phillips #000 screws that are slightly off-centered to the right.
    2. LG Cosmos Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the plastic opening tool to pry the motherboard loose.
    3. LG Cosmos Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Hold the motherboard from the top and bottom and slowly lift the motherboard until you feel a pull.
      • The flex cable is attached at the bottom of the motherboard and can be damaged if too much lifting force is applied.
    4. LG Cosmos Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Once the motherboard is lifted , rotate the motherboard up 90 degrees to the right.
    5. LG Cosmos Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use your finger to pull the flex cable out from its connector.
    6. LG Cosmos Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pull the motherboard away from the rest of the phone.
Johnny Phane
crwdns2935283:004/15/13crwdne2935283:0
91 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-63, Johann Spring 2013 crwdns2935289:0Cal Poly, Team 13-63, Johann Spring 2013crwdne2935289:0
CPSU-JOHANN-S13S13G63
crwdns2936753:030crwdne2936753:0 76
crwdns2959996:0crwdne2959996:0 2,422
