This guide is going to be explaining how to replace the motherboard on an LG Cosmos 3 mobile phone. For this replacement, you will only need basic understanding of how electronics are assembled.
Before completing this step, make sure your device is turned off. Once it is turned off, remove the back cover gently from the phone by prying under the clip near the camera.
Unscrew the six 2 mm screws from under the back panel.
Remove the rear casing by prying along the edge of the keyboard bezel, then along the outside edge near the camera button.
Take out the two 3mm screws on the metal plate covering the ribbon cable.
Remove ribbon cable cover.
Disconnect volume buttons and camera button from the mounts.
Remove the motherboard from the rest of phone by prying under the board to the side of the headphone jack.
Replace the old motherboard with the new motherboard by reversing previous step, and pressing with plastic tool near ends of board to snap it into place.
two keys on the slide out keyboard of my phone are not dead but hard to activate. hope this helps me get into the keypad and fix the problem. Thanks for the info. Randall in Nashville
This was easy to do: we had a Cosmos2 with a broken screen, but the motherboard fit into a Cosmos3 case and worked fine. Unfortunately, though, it won’t connect to the Verizon network anymore, even though the phone number appears in Phone Info (it was working in 2018). I’m thinking this is due to Verizon’s dropping 1G and 2G network support. Any thoughts are welcome!
