LG Cosmos 2 LCD Display Replacement
  1. LG Cosmos 2 LCD Display Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Cosmos 2 LCD Display Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Cosmos 2 LCD Display Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the plastic opener into the slot at the top of the device.
    • Apply gentle pressure with the plastic tool to pop the back case off.
  2. LG Cosmos 2 LCD Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opener to lift, and remove, the device battery.
  3. LG Cosmos 2 LCD Display Replacement, Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
  4. LG Cosmos 2 LCD Display Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opener to pry the rear case loose.
    • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
  5. LG Cosmos 2 LCD Display Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
  6. LG Cosmos 2 LCD Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
  7. LG Cosmos 2 LCD Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opener to disconnect the ribbon cable.
  8. LG Cosmos 2 LCD Display Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to disconnect the two cables that attach the motherboard to the case.
    • Note: Pull on the cables gently to prevent damage for future use.
  9. LG Cosmos 2 LCD Display Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the front case.
  10. LG Cosmos 2 LCD Display Replacement, Option Buttons: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
  11. LG Cosmos 2 LCD Display Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
  12. LG Cosmos 2 LCD Display Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
    • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
  13. LG Cosmos 2 LCD Display Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opener to pry open the front of the phone.
    • Slip the ribbon cable through the slit to fully separate the two pieces.
  14. LG Cosmos 2 LCD Display Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
  15. LG Cosmos 2 LCD Display Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Detach the ribbon cable with the plastic opener.
  16. LG Cosmos 2 LCD Display Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the spudger to pry the metal piece loose.
    • Remove the metal piece along with the two ribbon cables.
  17. LG Cosmos 2 LCD Display Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the front of the phone over and the old option buttons will fall out.
    • Insert new option buttons.
  18. LG Cosmos 2 LCD Display Replacement, LCD Display: crwdns2935265:018crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Cosmos 2 LCD Display Replacement, LCD Display: crwdns2935265:018crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a tool to pry open the LCD display. Remove the display and the circuit board that it's connected to.
  19. LG Cosmos 2 LCD Display Replacement: crwdns2935265:019crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the plastic piece from the circuit board by unlocking the switch on the plastic piece with a pair of tweezers.
  20. LG Cosmos 2 LCD Display Replacement: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a pair of tweezers, remove the tape.
  21. LG Cosmos 2 LCD Display Replacement: crwdns2935265:021crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using either your finger or the plastic opener, disconnect the cable.
  22. LG Cosmos 2 LCD Display Replacement: crwdns2935265:022crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Cosmos 2 LCD Display Replacement: crwdns2935265:022crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the LCD display away from the circuit board.
    • You shouldn't feel any resistance. If you notice resistance, make sure you have completed the previous step.
Nick White
crwdns2935283:010/18/13crwdne2935283:0
866 crwdns2915208:0crwdne2915208:0
Clemson, Team 13-1, Benson Fall 2013 crwdns2935289:0Clemson, Team 13-1, Benson Fall 2013crwdne2935289:0
CLEM-BENSON-F13S13G1
crwdns2935297:018crwdne2935297:0
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 2,582
