LG Chocolate Keypad Replacement
crwdns2869540:0crwdne2869540:0: 763
0
10
43
763
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2955944:0crwdne2955944:0: crwdns2931273:0crwdne2931273:0
crwdns2955970:0crwdne2955970:0: crwdns2937803:0crwdne2937803:0
    1. LG Chocolate Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Keypad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
      • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
    1. LG Chocolate Keypad Replacement, Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • You will need to use a Phillips #00 screwdriver.
      • Remove the four screws located at the corners beneath the battery.
      • Detach the back case from the phone.
    2. LG Chocolate Keypad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Chocolate Keypad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Chocolate Keypad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Take the case off by using a plastic opening tool.
      • Continue using the plastic opening tool around the sides of the device.
      • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
      • The back speaker will be connected to the motherboard.
      • This must be disconnected in order to remove the case.
    1. LG Chocolate Keypad Replacement, Sliding Front: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
    2. LG Chocolate Keypad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Keypad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
    3. LG Chocolate Keypad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Keypad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry off the plastic tabs that cover two screws, as shown in the first picture.
      • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
    4. LG Chocolate Keypad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Pry off the back cover from the front of the case using a plastic opening tool.
    1. LG Chocolate Keypad Replacement, LCD Board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Chocolate Keypad Replacement, LCD Board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Chocolate Keypad Replacement, LCD Board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pry the front speaker and wireless receiver out of the front case using a spudger.
      • They may be taped into the case, so don't be afraid to pry hard.
    2. LG Chocolate Keypad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Keypad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
    3. LG Chocolate Keypad Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Unhook the ribbon cable using that flat side of a spudger.
    4. LG Chocolate Keypad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Next, carefully remove the tape from the LCD board.
    5. LG Chocolate Keypad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Keypad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
      • The LCD Board in now accessible.
    1. LG Chocolate Keypad Replacement, LCD Screen: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The LCD screen is no longer connected to the LCD board.
    1. LG Chocolate Keypad Replacement, Keypad: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Push the keypad out from the front of the phone and remove it.
Maci Miri
crwdns2935283:001/18/13crwdne2935283:0
39 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-46, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-46, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G46
crwdns2935297:0132crwdne2935297:0
crwdns2936753:030crwdne2936753:0 43
crwdns2959996:0crwdne2959996:0 763
