LG Chocolate Camera Replacement
  1. LG Chocolate Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Camera Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Camera Replacement, Back Cover: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Chocolate Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Chocolate Camera Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate Camera Replacement, Sliding Front: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Camera Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Camera Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Camera Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Camera Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Camera Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pry off the back cover from the front of the case using a plastic opening tool.
  8. LG Chocolate Camera Replacement, Camera: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pry the connecting cable between the camera and the motherboard off of the board.
  9. LG Chocolate Camera Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate Camera Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a small screwdriver, carefully pry the camera out of its position.
    • The camera will seem stuck to the board because of its tape. Don't be afraid to pry it.
Thomas
crwdns2935283:001/18/13crwdne2935283:0
91 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 19-46, Regan Winter 2013 crwdns2935289:0Cal Poly, Team 19-46, Regan Winter 2013crwdne2935289:0
CPSU-REGAN-W13S19G46
crwdns2935297:022crwdne2935297:0
crwdns2942667:0crwdne2942667:0 376
