LG Chocolate 3 Side Buttons Replacement
crwdns2869540:0crwdne2869540:0: 636
0
13
41
636
crwdns2959984:0crwdne2959984:0: 0
crwdns2959956:0crwdne2959956:0
crwdns2959986:0crwdne2959986:0: 1
crwdns2959980:01crwdne2959980:0
crwdns2955944:0crwdne2955944:0: crwdns2931287:050crwdne2931287:0
Use this guide to replace the side buttons. Be prepared to deal with small parts, including screws and the buttons themselves.
    1. LG Chocolate 3 Side Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the phone off before starting the replacement process.
      • Place the phone face down.
      • Press your finger down on the indentation and slide the back plate off.
    2. LG Chocolate 3 Side Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 LG Chocolate 3 Side Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 LG Chocolate 3 Side Buttons Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using your index finger lift and remove the battery from the phone.
    1. LG Chocolate 3 Side Buttons Replacement, Rear Case: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
      • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
    2. LG Chocolate 3 Side Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
      • If needed, use tweezers to remove loose screws from the recessed holes.
      • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
    3. LG Chocolate 3 Side Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate 3 Side Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pull the rear case up using the spudger.
      • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
      • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
    4. LG Chocolate 3 Side Buttons Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
    5. LG Chocolate 3 Side Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate 3 Side Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Carefully remove the rear case from the phone.
    1. LG Chocolate 3 Side Buttons Replacement, Side Buttons: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers to remove the music button found on the side of the phone.
    2. LG Chocolate 3 Side Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 LG Chocolate 3 Side Buttons Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use tweezers to remove the volume control buttons on the opposite side of the phone.
Brenna Yagade
crwdns2935283:004/15/13crwdne2935283:0
40 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 12-35, Amido Spring 2013 crwdns2935289:0Cal Poly, Team 12-35, Amido Spring 2013crwdne2935289:0
CPSU-AMIDO-S13S12G35
crwdns2936753:030crwdne2936753:0 41
crwdns2959996:0crwdne2959996:0 636
