crwdns2959928:0crwdne2959928:0 ↓Use this guide to replace the damaged or cracked rear case of your LG Chocolate 3. You may just need to access the internals of your phone to do other work and this guide will help you do that too. Be prepared to manage small screws.
Spudger4.9
Place the phone face down.
Press your finger down on the indentation and slide the back plate off.
Using your index finger lift and remove the battery from the phone.
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
Pull the rear case up using the spudger.
Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
Carefully remove the rear case from the phone.
