This guide will walk you through the steps to remove the charging port from your LG CU400. It will help remove the battery, the lower half casing, the removal of the motherboard from the phone casing, and the removal and replacement of the charging port on the motherboard. Before doing this, be aware that you will be unable to use your phone until the replacement is complete and the phone fully reassembled. You should also be careful when handling the motherboard because it has delicate wires extending from it. This guide also requires a soldering iron that can be dangerous to use. The following video has information on micro soldering: https://www.youtube.com/watch?v=jGZKsuaJ...
            Push the button labeled 'PUSH' on the rear cover.
            To remove the battery, grasp the top front edge of the battery and pull the battery away from the phone.
            Remove the sim card by sliding the card out from under the retainer using either your fingers or a spudger.
            Remove the rubber covers in the highlighted locations using a metal spudger.
            Remove the six 3mm #000 flat Phillips head screws from the back of the phone using a Phillips #000 Screwdriver.
            Remove the headphone jack cover with your finger or metal spudger.
            Insert the metal spudger between the keypad assembly and back cover assembly and pry the two assemblies apart.
            Work your way around the perimeter of the phone with the metal spudger to separate the two assemblies.
            Once you have worked your way around the perimeter of the phone, you will have access to the components in the bottom half assembly.
            You should notice that the number pad is loose and can simply be taken out of the open phone casing.
            Using the spudger, start to gently pry the motherboard from the back of the phone and work your way around the perimeter of the motherboard.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Use tweezers to grab the black piece that these wires are attached to and simply pull it off the motherboard.
            Remove the display ribbon cable from the back of the motherboard using tweezers.
            Use tweezers to remove the top ribbon cable, mentioned in step 11, from the hinge area.
            Grasp either side of the motherboard and gently lift it away from the phone casing.
            The motherboard should be completely free of the phone casing, and you should have what is shown in the pictures.
            Locate the 6 locations that need to be desoldered.
            Using a desoldering braid and a soldering iron, remove the soldered connections. Use the website " How To Solder and Desolder Connections " for more information on soldering.
            You will need to coat the boxed area with flux liquid and then heat it with a heat gun while gently prying the charging port with the micro soldering tweezers. Use the video https://www.youtube.com/watch?v=jGZKsuaJ... for more information on micro soldering.
To reassemble your device, follow these instructions in reverse order, but refer to specific step's reminders.
